how to create a specific property node w/ VI script
I am writing a VI script to work with some multi column listboxes.  I need it to create a property node that gets a reference to the ItemNames field.  I see that I can create a property node via the invoke node method Create.Property Node, but how to get the ItemNames field specifically I so far can't figure out.  Can anyone help?
To be clear, I am writing code that looks like this:
...and when I run the script, I want it to produce this:
Right now it produces the MCL as expected, via the New VI Object node...but I don't know how to get the ItemNames created automatcially.  I thought it might be in the PropItems array but so far no luck.
thank you
(3,733 Views)
Accepted by bmishoe
The output of "PropItems[]" will be a one element array.  Index that element and wire the reference to an invoke node.  Select the method "SetProperty".
(3,711 Views)
Is there a fast way to figure out what index will refer to ItemNames?
thank you
(3,709 Views)
or wait, you're saying there's only one element in the array, I see...
(3,708 Views)
