how to create an executable file from a LabVIEW 8.6.1
Hello All,
I have a VI and want to make it an executable file, please let me know the steps required, thanks.
LabVIEW Intermediate I level!
Message 1 of 20
(51,158 Views)
First, you need to own the Application Builder. Does LabVIEW let you Build EXE?
Richard
Message 2 of 20
(51,156 Views)
Hey Bebeto,
First you will have to build a project to contain the VI.  Once the VI is located in a project, you can then simply right click on Build Specifications in the project explorer and select new Application (.exe).  You can find more details on this in the Software Engineering with Labview tutorial.  To run this on a computer without Labview, the computer will have to have the Labview runtime engine (which I believe is free).  Cheers, Matt
Message 3 of 20
(51,155 Views)
The LabVIEW application builder is only included in LabVIEW professional or higher. If you only have LabVIEW base or full, you need purchase it.
What LabVIEW version do you have? What level?
Message 4 of 20
(51,141 Views)
Hello All,
I have the LabVIEW 8.6.1 Professional Development System
I could not find the option on the Project Explorer to make it EXE as mentioned before.
Message 5 of 20
(51,128 Views)
Right click the build specifications and it will give you the option to biuld an application
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 6 of 20
(51,124 Views)
Try this:
Message Edited by mtat76 on 09-22-2009 12:55 PM
Message 7 of 20
(51,116 Views)
One can also try to read the manual.
Message 8 of 20
(51,114 Views)
And for step-by-step instructions, open Help and go to 'stand-alone applications'. You'll see an example and how-to listed.
Message 9 of 20
(51,110 Views)
Accepted by topic author Bebeto
Does anybody know how to read a manual?
Smiley Very Happy
Message 10 of 20
(48,454 Views)
