how to create an executable file from a LabVIEW 8.6.1
Exactly!!!!!
thanks to all of you!!!
Kudos!!!
LabVIEW Intermediate I level!
Message 11 of 20
(5,024 Views)
you should mark the person who solved your problem as the solution holder.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 12 of 20
(5,002 Views)
to do this all you have to do is go to the right corner of the solution you marked it will say options than hit unmark as solution and than go to the message you feel solved your problems...
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 13 of 20
(4,990 Views)
I want to create an executable without the Application Builder software. Does anyone know another software that does the same?
Message 14 of 20
(4,258 Views)
Why wouldn't you want to use the software that was made for that job (LabVIEW App Builder)?
Message 15 of 20
(4,254 Views)
Sure, C++, Python, Java, etc...  Just re-write your code in another language and build it from that.  Smiley Happy
But if you need to use NI LabVIEW for your code, then you'll have to use NI tools to build it.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 16 of 20
(4,241 Views)
Because i have to pay!!
Can you provide me one without pay it?
Message 17 of 20
(4,231 Views)
You either pay for it or don't build an exe. Your company should have budgeted for it when it purchased LabVIEW. The professional version is what should have been bought.
Message 18 of 20
(4,228 Views)
There is no such thing as another LabVIEW App Builder.  If you build an EXE from LabVIEW code you must use a LabVIEW run-time engine to run it on the host computer.  Those only work with code that is built with a NI App Builder.  The whole point is that you have to pay.  National Instruments is running a business so not everything is free. Smiley Wink
Message 19 of 20
(4,209 Views)
Always look at what you need when buying any product.  If you knew you were going to have to build an executable, then you should have either bought the Professional version or budgeted for the App Builder as an add on to whichever version you are using (Base or Full).
I recommend calling up your local NI rep and see if they can cut you a deal.  I've rarely had issues with them helping me out.  But they will be honest with you.
Message 20 of 20
(4,202 Views)
