how to create this code in labview
hello...
please helpe me for this Question
i have create this code "c" in " labview "...
ex c :
if portc.f1==1 {
    portc.f0=~portc.f0
ex labview :
if push button  ==1 {
   round led =~ round led
thanks...
Message 1 of 12
(4,704 Views)
If else statments are achieved using the Case Structure (see structures pallete).  Wire your control/value of interest (say the push button) as the input.  The case strucutre will perform different segments of code when certain conditions are met.  In your case, you will leave the "False" condition empty, only performing functions when the value is TRUE.
Message 2 of 12
(4,695 Views)
hello
first ... thank you for your help ...
i have ..
if push button value = true   round led = true
and
if push button value = true  ( not false )     round led = false
ok
thank you
Message 3 of 12
(4,676 Views)
set the push button action to Switch until released and use an event structure to detect value change.  This action sets the mechanical value back to false when you let go but a case structure is used to change the LED state when the value changes to TRUE (as you press it).
See attached image.
Message 4 of 12
(4,668 Views)
Is  your push button a "real" device and not a button on a screen?  Your "port" command leads me to believ you might be getting the state of a physical button and wishing to display a virtual (on-screen simulated LED) indicator.
Message 5 of 12
(4,654 Views)
Accepted by Azou_LabVIEW
pjr1121 wrote:
See attached image.
Why do people insist on using property nodes to get the value.  It has the same issues with race conditions as the local variable but is extremely slow (forces a thread swap to the UI thread).  Besides, you should be keeping the value of the LED in a shift register.
Message 6 of 12
(4,648 Views)
My bad.  I did this in haste on my way out to lunch.  I had intended a local variable.
But you are correct, the shift register is better still.
Message 7 of 12
(4,639 Views)
hello all ...
pjr1121 ... Zwired1 ...
thank you all for help me ..
Answer my brother   was best .  thank you very very much
Message 8 of 12
(4,606 Views)
@i_love_NI_LabV wrote:
Answer my brother @crossrulz  was best .  thank you very very much
In that case, you should mark my post as the answer and give Kudos to all useful posts (including the solution).  These are how you are to properly give thanks on the forums.
Message 9 of 12
(4,587 Views)
thanks you
Spoiler
Message 10 of 12
(4,573 Views)
