how to deploy a design?
So i have finished with the development in LabVIEW 7.1.  How do I create an installer that user can installs and uses the application on a different computer?
Message 1 of 16
(4,033 Views)
Hi!
   In the other computer, I suppose you don't have LabView installed.  In this case, you need Application Builder (see here).
   What LabView bundle do you have,the basic, full, developer suite....? In Basic LV 7.1 Application builder is not included.
   Hope this helps! Have a nice day!
graziano
Message 2 of 16
(4,031 Views)
yes, my LabVIEW 7.1 does have application builder.  I've looked in your user guide, it does not much detail.
I'm wondering if there is a complete step-by-step tutorial for creating executable and installer available?
Message 3 of 16
(3,964 Views)
There is a step-by-step procedure in the on-line help. Look for the topic 'stand-alone applications' and the sub-topic 'building'. Open that.
Message 4 of 16
(3,962 Views)
I've tried these steps (refer to attachment) but nothing only .bld file was save to destination directory.
shouldn't it create a .exe file and other support files in  the destination directory?
Message 5 of 16
(3,950 Views)
Sorry, but did you do step '9'?
After hitting 'build' some dialog should pop-up.
Ton
My LabVIEW Ideas
Message 6 of 16
(3,946 Views)
you're right a dialog did pop up really fast and then disappeared.
Message 7 of 16
(3,943 Views)
Did you in fact select a top level VI to create the exe from? Did you change the default location for the exe to be created in? The default is not the same location as the source file or the .bld file. Attach your top level VI and the .bld file to help to see what might be wrong.
Message 8 of 16
(3,935 Views)
This is what i did:
Tools>>Build Application or Shared Library (DLL)
     >Target tab:
          -Build target: Application(Exe)
         -Target file name: Calculator.exe
         -Destination dir: C:\myApp
         -Support file dir: C:\myApp\data
     >Source files tab:
         -Add Top-Level vi: Main.vi
         -Source file path: H:\projects\Main.vi
     >Installer Settings tab:
          -checkmark create installer
Save As: C:\myApp\Calculator.bld
Build
Message 9 of 16
(3,926 Views)
I don't see anything wrong. What happens after you click build? Do you get a pop-up with a progress bar?
Message 10 of 16
(3,911 Views)
