how to display duplicate strings in 1d string array
I have some strings in 1d array string and I need to display the duplciate strings present in the 1d string array...pls let me know..I am using labview 2010 ver
Message 1 of 8
(5,552 Views)
I would display them in an 1D array of strings indicator on the front panel.
If you are also interested on how to find the duplicate strings, do a forum search for e.g. removing duplicate elements, then adapt the code. Should be quite simple. There are plenty of wys to do that and some ways scale much better if the array are large. What have you tried so far? Is this for school?
Message 2 of 8
(5,543 Views)
I tried but i am not able to display
Message 3 of 8
(5,535 Views)
Just wire the array of duplicate elements to an indicator terminal. Show us what you tried so far and we can give you tips how to fix it.
Message 4 of 8
(5,530 Views)
I have attached the VI
Message 5 of 8
(5,521 Views)
Accepted by Mandya
Well, there are several possible solution. Do you want all elelemts that are not in the current output or do you only want one each. For example if the array contains 3 of the same element, do you want it twice in the duplicate output?
I assume you only want it once, so simply scale the existing code accordingly. See attached example. If you want all, remove the inner case and search node and blindly append all duplicate elements.
Note that there are singificantly more efficient ways to do all this, but the current code is sufficient for small arrays.
Message 6 of 8
(5,511 Views)
thanks for your solution
Message 7 of 8
(5,493 Views)
How would you return the number of times the string was repeated?
Message 8 of 8
(5,298 Views)
