how to eliminate elements in a 1D array
I want to know how to remove elements from 1D array. Let say 1D array has 30 elements. I want to keep initial 10 and get rid of remaining 20 elements.
How can I do that. See attached image for more clarification
JK
(3,426 Views)
Accepted by josephkirmani
Have a look at the LabVIEW Array functions. There's a delete from array or an array subset that you can use for your purposes.
Regards, Jens
Kudos are welcome...
(3,402 Views)
In  this case, I would use Array Subset.
(3,399 Views)
