how to empty clear cluster chart history labview 2011
Hi ,
Anyone can help me ?
How to clear the history data of cluster chart using labview 2011
Message 1 of 8
(5,320 Views)
This link should help 🙂
http://digital.ni.com/public.nsf/allkb/740628D210D84F1E862562BA0000B345
SK
TailOfGon
Certified LabVIEW Architect 2013
Message 2 of 8
(5,311 Views)
Thanks for your reply.
the URL which you provide only used for empty normal chart history.
Can not apply for empty cluster chart
Message 3 of 8
(5,303 Views)
Accepted by topic author qbell
Hi qbell,
the example is usable for any kind of chart. Just wire an empty array of clusters or, even easier, create a constant from your chart history property node!
Message 4 of 8
(5,300 Views)
Hi
Message 5 of 8
(5,297 Views)
Thanks!! All
It works.
just create constant....thanks
Message 6 of 8
(5,293 Views)
Hi!
I have the same problem as you. Could you show me how do you solve your problem eventually?
Thanks.
Message 7 of 8
(4,751 Views)
Did you read the thread? The solution was provided in the thread. Get a property node for the chart.  Choose history.  Right-click the input.  Choose Create->Constant.  Leave the constant blank.  History = cleared.
Message 8 of 8
(4,746 Views)
