how to end a vi after xxx seconds ?
hi folks
how can i end a vi after 10 mins?>  i got labview 8 and there is a plenthora or different time blocks, totally lost.........!
thanks
(3,321 Views)
There are lots of different solutions possible.
You could use the "Time elapsed" express vi, you could store a timestamp when the vi starts and compare it to a current time-stamp to calculate the time elapse (basically this is what the express vi does).
And there are other ways to do what you want.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,308 Views)
Here are a couple of easy ways:
Message Edited by Warren Massey on 02-16-2006 07:18 AM
(3,305 Views)
hi folks,
i tried one of them on my vi, which is very very messy, but it works.......(somehow!), can anyone alter this so it halts after 10mins?
regards
eric
(3,292 Views)
Attached is an example of how you could stop your VI. I've used the Elapsed Time Express VI. I also included a stop button as it's better to stop it that way then by using the Abort button.
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,267 Views)
