how to enlarge the picture at the same scale(proportion) of what
the fontpanel enlarged when you dbclick the title bar to enlarge the fontpanel to entire screen,but the other objects (for example,the button,the string,and so on)on the fontpanel not enlarged with the varity of the fontpanel, only keep the original size.Can anyone help me! my first question is :
how to enlarge the picture at the same scale(proportion) of what the fontpanel enlarged when you dbclick the title bar to enlarge the fontpanel to entire screen,but the other objects (for example,the button,the string,and so on)on the fontpanel not enlarged with the varity of the fontpanel, only keep the original size. i thank it is a representional question although it may be very simple,in
my around ,no one can solve it !
i have offered the vi and a jpeg file underside,who can help me amend the vi? greatly thanks!!! noticed that what i use is lv6.1,if you can solve the problem but need some other vi or lib files ,please offered all together!!!
thanks!
the second question is :whether there are some free package can application for image process! i have download some vi at the code library,but when some vi run,it need to open a "vision" folder ,then open display.lib,management.lib, pixel manipulation.lib ,files.lib of the "vision" older,finally to invoke vi named "imaq draw.vi","imaq winddraw.vi" "imaq readfile.vi" and so on ,i can not understand these! why my lv 6.1 did not have the lib files! is the edition not same?
(2,859 Views)
the fontpanel enlarged when you dbclick the title bar to enlarge the fontpanel to entire screen,but the other objects (for example,the button,the string,and so on)on the fontpanel not enlarged with the varity of the fontpanel, only keep the original size.Hi Pyi,
To answer your first question if you alter the vi properties (right click on the front panel icon) and select "window size" there is a "scale all objects" tick box at the bottom this shouls solve this issue.The imaq question I believe is a separate package which you need to buy.
Hope this helps,
Nick
(2,859 Views)
the fontpanel enlarged when you dbclick the title bar to enlarge the fontpanel to entire screen,but the other objects (for example,the button,the string,and so on)on the fontpanel not enlarged with the varity of the fontpanel, only keep the original size.To answer your first question:
To change the size of only the Picture you can use the Draw Area Size like you already have. However if you want to move the other controls around the picture, you may need to use their Position Properties.
On to question 2:
All of the VIs you are discussing come with the NI-IMAQ driver and NI�s Vision package. To use those VIs you will need to have the IMAQ driver and have purchased our Vision software. Machine Vision and then you can click on the Machine Vision Software link to learn more about the package.
Evan
(2,859 Views)
the fontpanel enlarged when you dbclick the title bar to enlarge the fontpanel to entire screen,but the other objects (for example,the button,the string,and so on)on the fontpanel not enlarged with the varity of the fontpanel, only keep the original size.Hi Nick,
Thank you for your help,but you haven't understand me! what you say i have tried many times ago,no possibile! the "picture"what i say is which made by picture control,not is to paste to the fontpanel only to as base image!!! the other ,i only want the picture control enlarge with the fontpanel ,but the other control's size not changed!! to you idea,it is just opposited! what i not want to enlarge have enlarged!
very thank you!
(2,859 Views)
