"why the active tree control(please notice me is lv 6.1,not llv7.0)'s branch always shrink when run the vi? i want it outspread (open out )at running ,needn't to dbclick to the plus to outspread!"
"why the active tree control( noticed!! lv 6.1)'s branch always shrink when run the vi? i want it outspread (open out )at running ,needn't to dbclick to the plus to outspread! i have a vi to demonstrate this ,it use two subvi,all have provided!
there are three vi to demostrate the problem ,who can help me?"
(2,557 Views)
Hello pvi,
Thank you for contacting National Instruments.
If you remove the Invoke Node from your Open Tree Control VI the problem disappears. Why were you using a "Clear" invoke node? This is what makes your tree collapse upon execution. It seems to work without the invoke node.
I have attached the altered Open Tree Control VI.
I hope this helps,
Sean C.
(2,557 Views)
