how to extract/detect which data set to display
I need a bit of help trying to figure out how to detect which channel of data has the data I want to display. There are four data channels, and only one has a sine wave in it. The others are all some sort of noise. Is there a quick labview routine that will allow me to perform this task easily?
thanx in advance,
-Quan
(2,818 Views)
Greetings, Quan:
The "Extract Single Tone" vi should do the trick. If there is a sine wave to extract, it will show up...if not, it won't! You can then use a comparator function set to some predetermined level to set a trigger on whichever channel the sine wave appears.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,818 Views)
Hi Eric,
Thanx for the tip. I tried the Extract Single Tone Information vi and it seems to do something. It is not doing exactly what i had hoped for but with a little bit more tweaking it might be even better than i had hoped for.
thanx again,
-Quan
(2,818 Views)
