how to extract time at every 210ms?
HI all,
         I am doing the project using labview 8.5, NI9012, NI9233 and NI9101.
Now the project is nearly finished.Smiley Happy
But there got a problem with the time extracting at every 210ms.Smiley Sad
i am using the write to measurement file for saving datas.
In the lvm file, there is a column called *X_Column* for time. Is it Right?
In this column, i would like to show the time at every 210ms like 0.21s, 0.42s, 0.63s, and so on until i press the stop button.
and also i would like to save the datas at every these milli second in this file.
Could you see the attached file for me?
Can you suggest me a way to do for it?
Thank you so much for your time.
I am looking forward your kindly reply.
With Respect,
                     Su
(2,558 Views)
Hi roxylat,
i thought this is solved. I can´t open your vi´s at the moment, but later. Smiley Happy Can you explain were you have problems, please?
Mike
(2,548 Views)
HI Mike,
             Yes, you solved for me last time.
It worked in testing example program.
But when i put in my project program, it doesn't work.
It always loops from 0 to 0.84s only again and again.
But when i took this part out, in the X_column, the time only shows always zero *0*.
So pls help me to check it out again .
But now in the attached file, i took out the time extracting part as it doesn't work.
Can you suggest the other way for me ?
Thank you so much for your kindly reply.
With regards,
(2,533 Views)
