read GSM modem
Hi. I need some help here..I have a program that use to read all the inbox message in the GSM simcard. GSM modem is connected to the pc serial com port. I used AT command AT+CMGL="REC UNREAD" to read the unread messages in the inbox. Between VISA write and VISA read, I put some delay which is 450ms. So far this is the suitable delay to get a complete data from the serial. Before this is used less that 450ms, and the number of incomplete data that I read from the serial port is high. But even though I used 450ms, sometimes I still cannot read a complete data. When i try read the serial port using the hyperterminal, I never get incomplete data. All the data are completed data. I wondering, is there any delay used in the hyperterminal? Why when I access the serial port using VISA write/read and hyperterminal I will get a different result?How can I make my program read the complete data as a hyperterminal? Is it about the delay? Please assist me..I may need an advice from you...thanks
Message 1 of 9
(4,462 Views)
Message 2 of 9
(4,461 Views)
You use a time delay. When that time has expired, you read the data even if not all data have been received from modem.
Hyperterminal uses no delay. When a character comes , it is been displayed.
Solution : Do not use time delay, use termination character, line feed.
Message 3 of 9
(4,441 Views)
sorry..can you give me an example to use the termination character, line feed?..I do not know how to use it in my program. I am worried that if I didn't use time delay, I might cannot process the data.
Message 4 of 9
(4,417 Views)
Message 5 of 9
(4,416 Views)
If i don't forget something, this will work.
Message 6 of 9
(4,408 Views)
thanks..I wil try this example in my program
Message 7 of 9
(4,384 Views)
hi Pnt,
I have try your example. I let my programming running for a whole day in order to read the messages received. But sometimes there will be an error occured. Sorry I forgot to save the error messages so that u can identify what's the problem.
Message 8 of 9
(4,345 Views)
My example was a demo.
I suppose you have modifie it.
Can you post your code, or a screenshoot ?
Message 9 of 9
(4,337 Views)
