how to find a object from the kamera which matches the example object
Im working on a projekt now. First find out a object from the kamera which matches the example object. Then measure the object (pixel), compare with the example object,  calculate the distance and degree between the objekt and the kamera.
Im trying to imitate the "Match Multiple Gemometric Patterns Example.vi" to find out the matches object. But i have a problem which i can not solve jet. It says "The file is not a resource file".
Any advice will be appreciate.
(2,446 Views)
Hello bondalfred,
Error 13 results from selecting a file instead of a folder in the Control: "File Path 1".
The default behavior of a File Path Control allows only files to be selected.
To change this behavior, open the Context Menu on the File Path Control (Frontpanel) and select "Browse Options..."
In the section "Selection Mode" check "Folders" and "Existing"
I hope this helps
Regards
Moritz M.
(2,430 Views)
