how to find eqation from graph (Problem)
i have 20 value randomly select then plot the graph. if it is possible to find eqation from the graph?
please reply quickly.
(2,853 Views)
You are looking into fitting of data. For that you need to decide on a suitable model.
It could be the equation of a straight line, a polynomial, or some really complicated function. Do you have more information?
You select 20 values from what randomly? How are the value arranged. Is there a pattern?
(2,838 Views)
Accepted by dhaval209
Try using
Curve Fitting
You can get all parameters for teh equation depending on the kind of model you are looking for.
Nghtcwrlr
(2,825 Views)
