how to fix the range of a waveform chart
I need to acquire waveform for a period of 5 seconds starting from zero. I use strip waveform chart. How to assign the starting of the X - axis as zero and final value on X scale as 5.
Thanks and Regards
(2,301 Views)
You just need to write to a couple of properties - XScale.Range.Minimum and Xscale.Range.Maximum. If you are not sampling once a second, write to the multiplier property.
(2,287 Views)
