producer consumer loop only execute once?
Hello here,
In my VI, the producer loop seems working continuously, but the consumer loop only execute once.
I haven't used producer/consumer pattern before, could someone give me some ideas why this happens?
My code is in attachment.
Thank you in advance.
Yaqiong
(2,531 Views)
Accepted by topic author Yaqiong
That would be the poor choice of using an event structure in the consumer loop.  As set up you must generate a mouse Leave or mouse enter event on Waveform Graph for the consumer loop to finish its first iteration.
Delete the event structure.  you don't need it to update a graph.
(2,528 Views)
Thanks you it works!
I was trying to use event loop so that when my mouse is on the chart the scroll bar doesn't automatically scroll to the newest updates so I can see the previous waveform. Is there a way to achieve this within a consumer loop?
Yaqiong
(2,513 Views)
