how to force the control switch to indicator in xcontrol?
@JÞB wrote:
"What is your LabVIEW version? (I don't see that "space" when hiding the browse button)."
Control style does seem to have some effect-  Scale object with pane doesn't-  Smiley Surprised  Hi-Ho Silver!  (DK is going to go nuts when reads this)
The "space" won't appear if I disable the button in the front panel. But if I change that with program in xcontrol (using property control), then the "space" will be there.
p.s. I try to set "Property -> BrwsButVis" as false, but it will only make the button in visible, I think it is not the same to uncheck Browser button in "Visibile Items"
Message 11 of 12
(380 Views)
Yup,  using a p-node after direction change is funky
Start                                Run (hide Browse)               RCM Change to ind         Dir change to Control + Run (Show Browse)
That overlap of the browse button is unfortunate-Smiley Sad  (But Silver isn't really a good GUI idea anyway right)  Superimposed control and indicator does seem to be the preferable method
Message 12 of 12
(373 Views)
