how to generate excel report daily using write to spread sheet
I am just trying to generate .xls file daily @ 12:00 AM using write to spreadsheet.
I am attaching my code . Please help me to have a solution.
Thank you in advance.
Message 1 of 16
(4,368 Views)
Hi sridhar,
there are two (main) problems with your VI:
1. With WriteToSpreadsheetFile you DON'T create XLS files - you are writing a text file with a common formatting. Please name those files *.txt or *.csv!
2. There is no comparison in your VI! How do you want to determine this "12:00 AM"? I suggest something like
IF 11:59 < Time(current) < 12:01 THEN save(data)
Please try this and ask again for specific problems…
Message 2 of 16
(4,338 Views)
Accepted by sridhar..reddy
Thank you for your support.
This code is working for me.
is there any other way to simplify it.
Message 3 of 16
(4,327 Views)
Hi sridhar,
- There is a "=0" comparison available…
- I would put a delay into the upper loop. No need to check the timestamp each microsecond…
- Cleaning up your VI is always a good idea…
(These are just some, but not all improvements I see!)
Message 4 of 16
(4,322 Views)
 There is a "=0" comparison available-- i had not understood this....
I would put a delay into the upper loop. No need to check the time stamp each microsecond…Thank you, i did it.
- Cleaning up your VI is always a good idea…I did it.
Thanks for your support.
Message 5 of 16
(4,316 Views)
Hi sridhar,
Message 6 of 16
(4,311 Views)
How come?! Smiley Indifferent
Your VI will keep running forever, with a False wired to the (top) While loop Stop terminal!
So, what are you trying to achieve by running the VI infinitely??
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 16
(4,302 Views)
hi,
I am going to use this vi as a sub vi with some conditions.
Message 8 of 16
(4,299 Views)
hi,
My vi should run for 20 days continuously with some conditional operations.
Message 9 of 16
(4,298 Views)
No need to use format the Timestamp into String, and then compare it with 12:00:00 AM! Simply compare it with a constant Timestamp, because String operation would be slower than simple TImestamp comparison.
Message 10 of 16
(4,291 Views)
