how to generate sine wave in DAQ 6009? please help me.
how will i generate continuous sine wave in DAQ 6009? Can any one give me the idea? if any one have the the GL program then please attach. thanks in advance.
Message 1 of 12
(7,620 Views)
Hi Ritesh,
there are many examples for doing just that and while I personally never use Express VIs, it's certainly a good point for you to start. Here's a step by step description: http://www.ni.com/pdf/events/us/aowaveform.pdf
Remember Cunningham's Law
Message 2 of 12
(7,606 Views)
Hi ritesh,
your DAQ device doesn't support continuous output on it's AO channels - as you have read in the manual (did you?).
You can generate scalar samples in any kind of signal you like and output them at max. 150Hz to those channels…
LabVIEW comes with a lot of example VIs, there are examples on analog output as well.
the GL program
What is a "GL program"?
Message 3 of 12
(7,603 Views)
Thanks GerdW
i read that it doesn't support continuous output on it's AO channel, then my question is how would i generate continuous sine wave through daq 6009..u said that LabVIEW comes with a lot of example VIs but where will i get such examples which supports daq 6009..do u have any such example or any link which generates sine wave through daq 6009.
and the GL program is basically i mean to say grapical language(labview example)
Best  regards
ritesh
Message 4 of 12
(7,554 Views)
thanks  PeterFoerster
as i am using daq 6009 and it doesn't support t continuous output on it's AO channel,therefore the pdf link you have given is not suitable for mu daq 6009.
Best Regards
ritesh
Message 5 of 12
(7,546 Views)
You need to place a DAQmx Write inside a for loop and pass a waveform into it. The autoindexing feature of a for loop will extract the waveform array point by point. A wait inside the loop will provide for basic timing. The timing will have considerable jitter because of the Windows os.
Message 6 of 12
(7,524 Views)
@ritesh312 wrote:
thanks  @PeterFoerster
Best Regards
ritesh
Thanks ritesh!
Sorry for trying and failing quite miserably to help you...
Message 7 of 12
(7,501 Views)
The PDF file is for the NI USB-6009. It is not suitable for your DAQ 6009 ????
How is that possible?
Message 8 of 12
(7,494 Views)
This should work, good enough at low frequencies, as long as LabVIEW operation is not delayed by other  programs in the pc
Message 9 of 12
(7,476 Views)
are you talking about this pdf http://www.ni.com/pdf/events/us/aowaveform.pdf ??
Message 10 of 12
(7,414 Views)
