pci 5105 - self test has failed!
I'm using NI PCI-5105. I try to start it by NI-MAX -> Test Panels, but error message "The device self test has failed. Do you want to continue?". When I choose in NI-MAX -> Self-Test, there is an error message "The device self test has failed. The error report from the device driver is as follows: Error -200313 occured at Self-Test" and "Possible Reasons(s)" is empty.
Few days ago this device worked properly.
Thank you in advance,
Agna
(3,028 Views)
Did you follow the steps on Page 13 of the Manual, ""What Should I Do If The Module Fails the Self-Test?"?  If it continues to fail, maybe it is "broken" -- the Error code is Hardware Clocking Error Occurred, and suggests that if you cannot fix it, to contact National Instruments Support.
(2,997 Views)
