how to get a time averaged data from DAQ 6009
I'am a research scholar . I'am doing a work which needs a constant voltage reading  from the DAQ 6009 card. Now whatever its giving is highly (for my work) fluctuating. So I need a averaged data from it for a interval of 100ms or something. Can I do it through daq assistant VI or outside I have to do or is there any way to solv ethis problem please reply.
Message 1 of 17
(3,835 Views)
Hi perumpadapu,
I usually stay away from ExpressVIs, so I would suggest this:
Set a channel to read continuously with a sample rate of 1kHz, read 100 samples per DAQmxRead (resulting in a read operation each 100ms) and calc the average of those values...
Message 2 of 17
(3,825 Views)
can you send a sample working program from screen shot I'am not able to make out what to do.I expect help
Message 3 of 17
(3,815 Views)
Hi perumpadapu,
this is a snippet!
And it's very basic, using only functions from the top-level DAQmx palette...
Message 4 of 17
(3,812 Views)
After DAQ assistant we have to make this program, Please reply
Message 5 of 17
(3,806 Views)
Hi perumpadapu,
if you really want to stick with your DAQ assistent you should set sample rate and number of read samples the same way I did and put in the average calculation as I did.
I do not recommend using ExpressVIs...
Message 6 of 17
(3,804 Views)
No other options other than this, because i need to average the sum of four signals from DAQ to 100ms, is it possible with this program. I had adjusted the sample rate and the frequency, but then also averaging is not happening. So please help me in this regard
Message 7 of 17
(3,799 Views)
Hi perumpadapu,
don't you think it will help when you attach your VI?
Do you really need to sum up 4 signals before averaging? Does it make sense to do so?
Message 8 of 17
(3,791 Views)
I'am sending the program which I wrote for aquisition, so please help me
Message 9 of 17
(3,763 Views)
Accepted by topic author perumpadapu
Hi perumpadapu,
yo did set sample rate and blocksize to get 100ms blocks of data? Really?
Then why are both set to "1k"? That way you will get data each second...
Then I told you to use the Mean function to calc averages. Did you even tried that?
Message 10 of 17
(3,756 Views)
