how to get data from tablet pen through USB port to labview front pannel
hi
i am trying to connect my tablet pen to pc through usb port. i need to measure pen position and charector recognisation from tablet using labview.
(3,238 Views)
I have this problem,too. and I hope one could help us: How can I read pen position on tablet through USB port and labview?
(3,149 Views)
The pen on a tablet functions like a mouse. You can get the position of the mouse/pen by using the Call library function node (Connectivity -> Libraries and Executables) in the functions pallete. You can use the user32.dll to call the GetCursor method for the pen position.
Sahil Singla
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(3,126 Views)
Thank you,But there is a predefined function in labview to get position of courser of mouse, can I use this function to pen?
(3,099 Views)
Yes, you can. It basically uses the same backhand architecture I mentioned in my last post.
Sahil Singla
Sahil Singla
(3,077 Views)
