how to get fitcsvm function of matlab in labview
I have one Matlab program designed for SVM classification. in that program, "fitcsvm" function is used. how can we design that in LabVIEW or there is any function in LabVIEW that can be used for the fitcsvm.
(2,621 Views)
Some of us know LabVIEW pretty well (I fall into this class).  Some of us know Matlab very well (I put you in that class).  Some have some knowledge of both (I also am in this class), but might not be sufficiently "up" on Matlab to have a clue what "fitcsvm" is (and might not have access to Matlab to find out).  You might get more help from the LabVIEW gurus if you provided more information (and fewer terse abbreviations) on what functionality you need.
Bob Schor
P.S. -- I started learning/using LabVIEW about 13 years ago, and stopped using Matlab at around the same time.
(2,618 Views)
Based on the description at the MATLAB Help Page and the information in the overview of the LabVIEW Analytics and Machine Learning Toolkit, I'd say there's probably a function there that will do what you want (SVM classification).
Unfortunately I have neither the MATLAB "Statistics and Machine Learning" toolbox or the LabVIEW "Analytics and Machine Learning" toolkit installed (or downloaded), so that's as far as I can easily get.
GCentral
(2,582 Views)
