01-23-2008 01:25 AM
01-25-2008 05:20 AM
Hi eyal,
From my understanding, you are using the DAQ Assistant in LabVIEW 7.1 to take in an analog square wave. You would now like to get the frequency of this periodic signal. You could use the Spectral express VI. When you right click on the block diagram and look under Express>>Signal Analysis, you can select Spectral. This express VI will calculate the FFT of a signal that is input into it.
I hope this helps!
