modbus ASCII library
Does anyone have some example on modbus ASCII library??
thanks...
Message 1 of 11
(7,116 Views)
currently i'm using this program. but when i send 3A30 3330 3430 3030 3030 3030 3246 370D 0A to my device. nothing happen.my device not responding. what should i do??
Message 2 of 11
(7,114 Views)
Are your settings correct?
Does this work with these settings in programs like Modbus Scanner?
___________________
Try to take over the world!
Message 3 of 11
(7,097 Views)
hi tst,
yes,my setting is correct. i referred to the decive manual.mode=ASCII,flow control=none, parity=even, baud rate=19200. i using the same program for power relay device in different setting and it's working. but when i used the same setting as i mention before,it's not working. do u have any labview program that using modbus library??if u do, then mayb i can test it with my device..
thanks
Message 4 of 11
(7,086 Views)
hi tst,
thanks
Message 5 of 11
(7,083 Views)
gdah,
Here are some more serial settings to double check for ASCII mode.
Start Bit = 1
Data Bits = 7
Parity = Odd, Even or None depending on the device you are communicating with.
Stop Bits = 1 if parity is set to Odd or Even, 2 if parity is set to None.
Message 6 of 11
(7,072 Views)
It seems that there is a bug in the original Modbus library when the number of coils/register is greater than 16. I have not tested it because this is not the case in my application.
Please see the comments and their links at the bottom of this page.
Message 7 of 11
(7,060 Views)
Which would indicate that the code works. My guess would be that the manual is incomplete or that you're not performing a required step.
As I said, I suggest you try using a program like Modbus Scanner to connect to the device. If you can't do it there, you won't be able to do it in LabVIEW.
___________________
Message 8 of 11
(7,045 Views)
thanks everyone..
i'm appreciate your helps..maybe there are some missing information of my device that i not realize. i will come back to you if i have problems..
thanks...
Message 9 of 11
(7,011 Views)
hi everyone..
i have read all the information about the software. but my device stil not working.can anyone help me??i hav e download a modbus scanner from internet. i tested with my device but unfortunately it stil didn't work. I used mode=ASCII, parity=even, baud=19200,bit data=7, stop bit=1.I get wrong data when i want to read input registers value. if anyone have another modbus scanner that mayb will solve my problem? Right now  i stil do not know either my connection serial setting is correct or not.
Message 10 of 11
(6,991 Views)
