how to get sub cluster element's caption?
Hi All,
I have a big cluster, which contains several sub clusters. They are all typ def.  My queation is,
how to get the sub cluster element's caption?
Thanks.
Anne
(4,008 Views)
Try this.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,988 Views)
Thanks for your help.
BUT, I couldn't open them since I am using Labview 8.5.1.
Could you  please attach the screen copy of the diagram or convert it to 8.5?
Thanks a lot.
Anne
(3,961 Views)
Accepted by Anne Zuo
In this Nugget  you will find a lot of images that illustrate how to get at elements within a cluster. The ideas are the same, you will be looking for the caption.
Have fun!
Ben
(3,954 Views)
Find the VIs in 8.5
Balaji PK (CLA)
(3,934 Views)
Thanks.  Problem solved.   🙂
(3,911 Views)
Hi Anne,
If your problem solved, then mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
(3,895 Views)
