how to get sub cluster element's caption?
Hi All,
I have a big cluster, which contains several sub clusters. They are all typ def.  My queation is,
how to get the sub cluster element's caption?
Thanks.
Anne
(4,473 Views)
Try this.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,453 Views)
Thanks for your help.
BUT, I couldn't open them since I am using Labview 8.5.1.
Could you  please attach the screen copy of the diagram or convert it to 8.5?
Thanks a lot.
Anne
(4,426 Views)
Accepted by topic author Anne Zuo
In this Nugget  you will find a lot of images that illustrate how to get at elements within a cluster. The ideas are the same, you will be looking for the caption.
Have fun!
Ben
(4,419 Views)
Find the VIs in 8.5
Balaji PK (CLA)
(4,399 Views)
Thanks.  Problem solved.   🙂
(4,376 Views)
Hi Anne,
If your problem solved, then mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
(4,360 Views)
