how to get the autosizing property of cluster from program
When creating cluster on front panel, it is possible by right click to select the autosizing property, I would like to be able to do that dynamically from inside my program, but do not find how.
Does somebody know how to do that???
(2,765 Views)
Here it is...
Chilly Charly    (aka CC)
(2,749 Views)
But I can not open it, I'm using Labview 7.0
Could you put this on ver 7.0  thanks
(2,742 Views)
Hre is CC code as LV 7.0.
Warning!
This property is not supported and if you have trouble with it..... you have no hope of getting help (from NI).
See the LAVA forum for more info on LV Scripting.
http://forums.lavausergroup.org/index.php?showforum=29
Ben
Message Edited by Ben on 11-27-2005 01:32 PM
(2,733 Views)
thanks,
Seems I to go to the forum your point out to understand how you create this!
BTW thanks again
(2,714 Views)
