how to get the time from a file recorded?
Now my boss give me another problem.
The "Identification" part can be a lot of words.. or can have numbers like "File number 3"
Have a way to "desconcatenated" a string?? Because I don't know the begginning of string...
from that string, I only need the TIME.... the hour, minutes and second...
or may have a way to only read it from that string??
Something like that
I send in a string a lot of informations, and now I need to read only the time.
Thanks for the help
Message 21 of 22
(547 Views)
Hi EduU,
it always helps to know the format of the data.
Maybe there is a known number of (header) lines or a special keyword signalling the timestring - something like this.
Or ask your boss to give you / create a written specification of the file format...
Edit:
There's a search function using RegularExpressions - atleast in the recent versions of LabVIEW. That would also help in searching a timestringin a text - when the format of that timestring is known and fixed (see comments above)...
Message Edited by GerdW on 04-14-2010 07:09 PM
Message 22 of 22
(531 Views)
