how to get two separate data in a single excel file
I have a VI from where i get data in 3 columns.I have added a subVI & wants the data coming out of it to be stored in the 4th column along with the initial data real time.How can i do that?
(2,719 Views)
Hi Labfreak,
your question title is only loosely related to the explanation in the message body... It doesn't need to be an Excel file?
Anyway the attachment shows two ways of adding a 4th column...
(2,714 Views)
Thanks a lot for the reply.But i am currently using 8.5 version & the VI attached is of 8.6.Can you please post one which i can open in my version.
Thank you,
Labfreak
(2,704 Views)
Hi LabFreak,
you didn't note your LV version. A great place to do so is your signature...
(2,674 Views)
