how to get what day from ActiveX calendar control
Thanks a lot.
I see your code is not finished, just don't know how to do the calculation.
Now, I get it.
Thanks again.
Anne
Message 11 of 12
(634 Views)
OK. Keep in mind that I was sticking with the calendar control, which is what you said you were using. You should consider using the MonthVIew control instead, since as ceties' example (in which he used the MonthView control) shows, that control will provide the numerical value of the day of the week.
Message 12 of 12
(632 Views)
