how to give a path for text file
hi,
 how can i choose a path for txt file.Here i have to choose only the path without .txt file name.File name should be create according to the data value. i have to choose only  for example C:\Dokumente und Einstellungen\adhikari-thakur\Desktop\tmp\ .I can do it using it as constant path but i have no idea how to select it using browser Without choosing file name.I have attached here my vi.
thanks.
Message 1 of 13
(4,516 Views)
here is my vi..
Message 2 of 13
(4,515 Views)
Sorry, I don't have LV2011, but if you can downconvert your code I would be happy to take a look.  I don't really understand your question, but I think you're asking how to select the file without browsing or having a path constant?  Use a file path control, browse to the file you want loaded and set it as the default.  Is this what you want?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 3 of 13
(4,503 Views)
So you only want to select the folder?  You can set the browse options of the Path control to look for only existing folders.  Would this solve your problem or is there something else?
Message 4 of 13
(4,497 Views)
Yea, I didn't get that from his post, but re-reading with this in mind, it appears that is what the OP is needing.
Message 5 of 13
(4,493 Views)
is this what you meant? it should also work...
Message 6 of 13
(4,490 Views)
I think that is what he is trying to avoid.
Message 7 of 13
(4,482 Views)
Message 8 of 13
(4,467 Views)
Accepted by tadhika
As Crossrulz said look at the Browse Options (right-click on the Path control and select Browse Options...). You can also set the start path, in your case it could be C:\Dokumente und Einstellungen\adhikari-thakur\Desktop\tmp\.
Ben64
Message 9 of 13
(4,462 Views)
ya, this is waht i am trying to avoid.
Message 10 of 13
(4,418 Views)
