how to implement this C code line: for ( int i = 0; i < G_ReadLen; i = i + 2 )
I want to implement the following C++ code in labview but i cannot make or loop to increase by two
int j = 0; for ( int i = 0; i < G_ReadLen; i = i + 2 )
BYTE AD_H = ByteArray.GetAt(i);
BYTE AD_L = ByteArray.GetAt(i + 1);
ValueArray[j] = AD_H << 8;
ValueArray[j] = ValueArray[j] + AD_L;
unsigned long Temp = ValueArray[j] >> 12;
Volts[j] = ((float)ValueArray[j]) * 0.0048875;Message.Format(
"%X , %X - %X, -- %d, +%.3f Volts", AD_H, AD_L, ValueArray[j], ValueArray[j], Volts[j]);
m_output_ep1i.InsertString(0,Message);
j = j + 1;
Message 1 of 9
(4,033 Views)
Hi nick7,
you can use a for loop and connect the duration number to n, calcualte the i value you need inside the loop.
Mike
Message 2 of 9
(4,030 Views)
Hi nick7,
You could also use a while loop with the loop termination condition as i < G_Readlen and within the loop increment i by 2 and j by 1. You would need to pass the values of i and j to shift registers.
Hope this helps!
Cheers!
Sanka
Message 3 of 9
(4,009 Views)
Accepted by nick7
Thanks a lot sanka problem solved I atached the solution
Message 4 of 9
(3,987 Views)
Your code will not work.
You are replacing elements of an empty array. A no-op in LabVIEW.
Besides there is a lot easier way to do this:
I just hope this is not a homework assignment.
And for completeness sake here is Mikes solution (seen below):
Ton
Message Edited by TonP on 11-14-2008 12:55 PM
Message Edited by TonP on 11-14-2008 01:03 PM
My LabVIEW Ideas
Message 5 of 9
(3,976 Views)
Hi nick7,
in your case the attached code should also work.
Mike
Message 6 of 9
(3,975 Views)
I love the way LabVIEW has tidied up all that C code (which took me a couple of minutes to get my head round). I then opened Mikes post (Which took up about 20% of the real estate) and recognised what was happening in about 0.5 secs! gotta love it! 🙂
LabVIEW 2012
Message 7 of 9
(3,961 Views)
Top my code is workig fine.
Here a few words on what I am doing:
PIC18F4550 micro board --> USB bulk in enpoind read delivers an array of 704 bytes (every two bytes contain a 10 bit voltage value)-->procces data to end up with 352 word (16bits) data.
HI byte XXXX XXDD  DDDD DDDD low byte (X :dont care bit)
Message 8 of 9
(3,915 Views)
Most likely you do a 'String to U8' node conversion.
If you replace that with the Typecast I used you can directly convert from string to U16 array.
The fact that your code works is propably becuase you have a hidden constant to the Array shift register.
Good luck,
Ton
My LabVIEW Ideas
Message 9 of 9
(3,870 Views)
