Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to insert flash power point??
i want to link my button with  to the power point using active-x.. can i get a example to do this
(3,201 Views)
Hi snta1806,
can you explain a bit more? What shall the button do? Do you want to start a presentation with it?
Mike
(3,198 Views)
yes,i want to start my presentation when i click the button. after that,if i close the presentation,the original page will display(vi)
(3,193 Views)
Hi snta1806,
see this link please.
Hope it helps.
Mike
(3,190 Views)
You can also use the attached VI that opens a file using it's associated application. It's made for pdf's, but works for any file type that has an application assigned. If you have a pps file it should start the presentation automatically. If it's a ppt file it will just open it in Powerpoint, but not start the presentation.
Daniel
(3,185 Views)
