how to maintain data in a boolean array
@Gombak wrote:
There are 8 elements in the Boolean and 8 elements of the numeric control array as well
No, there are only five elements in the boolean array. Why don't you resize the container so eight elements show and see for yourself? (Only 5 are there, the others are greyed out). As I said, use "initialize array" to avoid all confusion. (you can also click the eight element on the boolean array diagram constant twice to make the array larger. (the first click makes the last boolean true and resizes the array, the second click makes it false again, but keeps the array at size=8)
(for those who are confused, he's now actually talking about my answer in this thread)
Message 21 of 28
(1,397 Views)
yes I got what you mean by 5 elements .... you don't consider the ones with gray colour ...
I did resize them but the problem still the same I don't know why it works only for 5 elements
I don't know where to use the initialize array .... I tried so that the output of the initialize array becomes the input for 1D search array ... but error occurs ... what is the purpose of the initialize array
Message 22 of 28
(1,392 Views)
... then show us your new code if you still have problems. you also might consider reading the help for some functions.
As I said, it is not sufficient to resize the array container, you also need to make the array longer. Did you?
Message 23 of 28
(1,379 Views)
I removed the Boolean then put it again .... and I am using 12 elements of array but only 5 work
Message 24 of 28
(1,369 Views)
I was talking about the boolean array diagram constant. It still only has 5 elements. (see picture)
resizing an indicator has no effect, of course.
Message 25 of 28
(1,363 Views)
An here's how you would use "initialize array" to create a boolean array with 8 FALSE elements.
Message 26 of 28
(1,360 Views)
The array constant that you use to initialize the shift register has only 5 elements.  Rather than a constant you might be better off using Initialize Array. Then you only need to change the size constant to change the number of elements in the array.
You should also use the same representation for Array as you use for USER.  Because the Search array looks for exact matches, integer data types are a better choice.
Lynn
Message 27 of 28
(1,358 Views)
altenbach ,johnsold
Thank you so much
it solved the problem ... it is great
Message 28 of 28
(1,345 Views)
