how to make subvi's when I make use of event structure
Hello Everybody
I don't really get how to make use of subvi's when I use event structures in the vi?
When just making the buttons connectors on the subvi and assign controls to them the vi stops working as I expected.
I added an example vi that I don't get working as an subvi.
Thanks in advantage.
(3,216 Views)
The VI you have attached works. Can you attach the version that does not work?
(3,211 Views)
Accepted by Patrick Kerstholt
I dont think you generate any value change event through the input connector, as you hope to do. A semi-ugly workaround is to get the Button references and do a Value(Signal) property.
A better way if you want to handly events in a sub-vi is to register user events and send the event register-thread to the sub-vi, where you can use those events in the event structure. Check the User created event and Dynamic event examples.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,206 Views)
(3,182 Views)
Check that link. Maybe it will help you.
http://digital.ni.com/public.nsf/allkb/A882E27D1D7A949386256E0D0066B91A?OpenDocument
(3,157 Views)
