how to make text appear n disappear?
When an event is true, a text will appear on the front panel. When false, the text disappears.
I do know we can use a property node for other thigns like LED, but i have no idea how to do it for text.
Pls help.
p/s - i am not talking about pop-ups
TQ
(3,622 Views)
Accepted by fmpfmpf
Hi fmpfmpf,
you can use a string indicator. Place it outside your case our event structure to set different value for your different cases.
Mike
(3,619 Views)
MikeS81 wrote:
Hi fmpfmpf,
Mike
  To add to Mike's comment:
...make it a "Simple String" indicator from the Classic pallete and change the border and background to transparent for best effect if you are trying to do what I think you are.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(3,610 Views)
Thanks Mike and James for your suggestions!
Kuntal Ray
(3,292 Views)
