how to make while loop stop when i set while loop at a fixed time.
i don't know how to make while loop stop at a fixed time. Usually. while loop stops when we enter stop button or mistakes have been made. now i wanna while loop stop at a fixed time, 20ms,40ms,and so on. how can i realise that. thank u!
(3,396 Views)
Accepted by tangliang
Use the Tick Count function. Get the current tick count when you start the loop.  Add your time (20 ms) to the start value creating a "stop time." On each iteration read Tick Count again and compare the current value to the "stop time" value.  If greater, then stop, otherwise continue.
Note that on a desktop operating system you will see some jitter when trying to use loop times as small as 20 ms.  You may need to go to a real time system or something hardware timed to get any precision or stability at those time scales.
Lynn
(3,395 Views)
wire the stop with a true constant, this will execute the loop once and wire a cntrl to the wait (ms)
maybe this is not what you want, not realizing you may want code to continuosly run for a certain time allocated...
(3,387 Views)
thank u so much!
(3,358 Views)
thank u!
(3,356 Views)
