how to open image folder
Hi everyone, firstly I admit that I am totally new for labview. Now I want to try to open a folder which has so many images. I don't know which VI I should use. If anyone knows, pls kindly help me. Thanks millions.
(3,136 Views)
Accepted by why_so_serious
If you want to get the file names, use the "List Folder" function that is present under Adv File Funcs in File IO Palette.
Citra
(3,135 Views)
Thanks for your answer. That's work for me. 🙂
(3,119 Views)
Hi why_so_serious,
please explain your program a little more, you just want to open a folder and then whay you have to do, for opening a floder you can use open/create/replace File.vi or you can also use File Dialog vi depends on what do you want to do after, you can also check the link below this might help you.
http://forums.ni.com/t5/LabVIEW/Open-Folder-to-Browse-aka-Open-windows-explorer-to-known-folder/td-p...
(3,110 Views)
