how to output a digital signal on negative slope of the clock?
Hi
I need to output a finite length of the digital pulse which will start on demand at the negative slope of the imported (or exported) clock.
I am trying to get the clock exported or imported, but in no case I can trigger outputting the signal on the negative slope.
What is the trick?
thanks
Pawel
(2,704 Views)
Accepted by pawel
Which device are you using to generate your digital signal.  What is the clock source?  Can you attach your vi?  Normally, there is a DAQ function to configure the trigger where you choose the trigger source and the trigger slope (rising or falling), which would be falling for a negative slope.
20459i88EFC2074FC3AF52
- tbob
Inventor of the WORM Global
(2,703 Views)
Hi
That's it.
Pawel
(2,699 Views)
