how to plot waveform graph output on a table
    I am doing a project where in i need to plot the output from the waveform graph  by using a table or spreadsheet to see the change in data with respect to time.  i am doing a project to measure the heat flow and its effects. i am trying to show the change in heat flow with respect to change in colour. i am also trying to show this data by means of change in colour when there is an change in data in an intensity graph. but its not working. can someone please help me to solve these problem...   thanks in advance..
Message Edited by vineetmv on 03-11-2008 12:04 PM
(2,955 Views)
Hi vineetmv,
to store your data you could use the write spreadsheet file function. Can you show your code??
Mike
(2,916 Views)
Hi vineetmv and Mike,
this post is related to that...
(2,910 Views)
