codas wrote:
> Is there a way to find out, if there are data on an open tcp/ip port
> without reading them? And when, what can I do or where can I find an
> example? I'm using LV 7.
No, this possibility does not really exist with the TCP/IP icons.
Or wait a minute, maybe if you would use VISA to open a resource
"TCPIP::
::::SOCKET", the VISA functions
probably work similar on that resource as they do on serial port and
GPIB and might give you an indication of the bytes in the buffer through
the appropriate property node.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
