how to produce the digital random generator,which counts 0 and 1 randomly
hi , i want to generate the digital random generator for my project,which counts the 0 and 1 randomly. can anybody help me in doing this.
Message 1 of 13
(7,664 Views)
Hi ravi bagade,
i'm not sure if i completly understand what you mean, but if you only need 1 OR 0 randomly, then you can use the attached example.
Mike
Message 2 of 13
(7,651 Views)
thanks... i  want to generate the serial 10 bit digital random data ,so that i could see it on digital graph. The block which you have sent produces the 0 and 1, but it is not digital, as it cannot be plotted.
Message 3 of 13
(7,639 Views)
Sorry,
but i don't understand it.
If you have a number which type ever, then you can create the digital representation out of it. In your case i think you need 0 to 1023. You can create these numbers randomly with the random block, shown on the image from previous post and multiply the result by 1023. Round it to U16 and create your digtial data from it. After this you can plot it on a digital graph.
Try to help.
Mike
Message 4 of 13
(7,633 Views)
Hi Ravi,
This will create a random digital waveform. Just need to set the Bits, 10 in this case, and sample rate.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 5 of 13
(7,571 Views)
sir i have generated the serial data. no i am facing problem in sending that data to the daq 6251. also i use the scb 68 cionnector. i want the code do that.
Message 6 of 13
(7,515 Views)
If you want a boolean out instead of a numeric,
Take Mike's first reply (Random -> Absolute Value) and Add an "=0" comparisson on the end, this will give you an array of T/F.
Edit:
Alternatively If you want it as a different representation, use the adapt to type functions to chane the type.
You can always ensure it is whatever numeric range you want if you use the boolean method wired to a T/F comparrison and wire the constant values you want to the inputs.
James
Message Edited by James W on 05-10-2010 11:26 AM
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 7 of 13
(7,492 Views)
Arghh
Timed out when I was editting again to add a pic
James
Message 8 of 13
(7,483 Views)
Your question has been phrased in a way to cause confusion to what you actually want to achieve. Are you trying to display the random generator like a bit stream on a graph ie:
If so then this vi will do that:
Every time you press the 'Generate' Button it will create a digital array according to the 10 bit random number generated and display on a graph.
There is a way of doing this using a 'Digital waveform graph', i personally have never used it and after about 5 minutes of just looking into it for you gave up Smiley Sad It is something i should spend the time to look into as it presents your digital data nicely, showing the 0's and 1's within the graph.
If i have misunderstood what you want again i apologise
Rgs,
Lucither
Message Edited by Lucither on 05-10-2010 06:27 AM
Message 9 of 13
(7,462 Views)
 A digital random generator does not "count", but "generate". Your question makes no sense.
To generate random 0,1 data, have a look at the "Bernoulli Noise" from the signal generation palette.
Message 10 of 13
(7,459 Views)
