how to program a conditional in LabVIEW
Hello. I want to program a relay using cRIO and i made a manual control but i need a program that, if my input is <0 turn on the button automatically and if the input is >0 turn off the button  automatically in order to send my input with possitive and negatives numbers to my power supply.
Message 1 of 12
(4,815 Views)
If yo show us what you have so far, we might be able to give you some tips.
Message 2 of 12
(4,790 Views)
And what if the input is 0?  Assuming 0 should be on, then just use a Less Than Or Equal To Zero.  If 0 should be ff, then use Less Than Zero.
Message 3 of 12
(4,771 Views)
My input is an excel with a measurement and it never will be 0, so I need a program that if the valiu is under 0 run my program with the cRIO digital output in order to activate a relay and if the value is above 0 stop the relay automatically
Message 4 of 12
(4,749 Views)
hello, I've uploaded two screenshots of my program.  I need something that, if the input is less than 0 change the case to True and the relay goes on and if the input is greather than 0 change the case to false and the relay goes off.
Message 5 of 12
(4,714 Views)
Accepted by topic author GokuJubilao
Just do a comparison with 'less than 0' and send the result to the relay. No Case, number to bool array or index array needed!
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 12
(4,710 Views)
In case you missed it, "the results after the add..." is an array. How do you want to check if it is greater or less than zero?
Former Certified LabVIEW Developer (CLD)
Message 7 of 12
(4,695 Views)
All the elemens of the array must turn on/off the relay, i don´t know if that is a problem
Message 8 of 12
(4,690 Views)
That makes no sense unless you have as many relays as you have elements. If the array only has one element, it should not be an array.
Otherwise you need to decide based the suggestions above, e.g.
  • Should it turn on if all elements are less than zero?
  • Should it turn on it at least one element is less than zero?
  • Should it turn on of more that 50% of all elements are less than zero?
  • etc.
Message 9 of 12
(4,676 Views)
I have to program a power supply but and i want that, if my input is less than 0 the relay reverse the polarity of the current and if is greather than 0 turn off the relay. There is no possibility to do that? Can´t convert my array in numbers one by one?
Message 10 of 12
(4,648 Views)
