how to put the proper header at each column in write to measurement file (.lvm) ?
Hi Roxy,
i think you have to filter the data you want from the data you have.
Hope it helps.
Mike
Message 11 of 21
(1,569 Views)
hi,
            Could you please tell me more details about what you've said? and how to filter ?
Thank you so much.
With Respect,
Roxy
Message 12 of 21
(1,560 Views)
Hi Roxy,
i´m not sure if there is an easier way, but this should also do what you need.
Mike
Message 13 of 21
(1,556 Views)
Hi
     Thank you so much. It works but why the X_value column(time column) is empty? Why didn't show time like 0.21, 0.42, 0.63 and etc.?
how could i prove it that the outputs are for time interval at every 210ms?
thank you
Roxy
Message 14 of 21
(1,543 Views)
Hi Roxy,
can you show how you do it? If i use the code from the before attached picture, then i get this column.
Mike
Message 15 of 21
(1,537 Views)
hi Mike,
           here is my program that is same as yours. If possible, could you post your .vi as well ? Thank you .
Roxy
Message 16 of 21
(1,516 Views)
hi,
    Is the "X_Value" column for the real time? I need the extract time line because i want to get the data only at the specific time(which is at 0.21s,0.42s,..) . let's say the "X_Value" column shows like 0.21, 0.42 etc...does it mean that input is at every 0.21s  OR  just show the counting numbers sequently?
Thank you so much for your time.
Roxy
Message 17 of 21
(1,509 Views)
Hi Roxy,
you use the option "empty time column" change it to "one time column". Attached you will find an example. In the example every value comes every 1ms. I set it in the for loop (dt), because  you said you get your values every 1ms.
Mike
Message 18 of 21
(1,488 Views)
hi,
thank you for your help.
So is 0.21s(shown in the lvm file) the actual real time ?
But when i run the program for 5 seconds, there show the time more than 19 seconds in the (.lvm) excel file already .
Why didn't match these two ? Shouldn't these two match together?
i am looking forward your kindly reply.
with Respect,
Roxy
Message 19 of 21
(1,481 Views)
Hi Roxy,
in the example it is not the real time. We create an array of 20000 values and set the dt to 1ms. If you read your data from the hardware, then you have the real time stamp and then it is the real time.
Mike
Message 20 of 21
(1,478 Views)
