how to read a cell's value from a line
Just in case you can't find them, there are a couple of links to tutorials at the bottom of this message. Once you work through them, Google more.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 11 of 27
(1,566 Views)
this is what i do .
Message 12 of 27
(1,556 Views)
That's because you are not using the 2D array output.
Message 13 of 27
(1,548 Views)
It is also just silly to keep reading the same file over and over. Move it to outside the loop. Same thing for the Index Array if it's always the same column.
Message 14 of 27
(1,546 Views)
if i do that ,anything is working. i am going to explain you what i want to have.vr.PNG
Message 15 of 27
(1,530 Views)
That makes no sense. How do you create a waveform from a single point?
Message 16 of 27
(1,519 Views)
you read the value of the point.
if the first line is over. we start the second one.
values which are in a same column will be in a same waveform.
for example 10 and 40 are in a same waveform
Message 17 of 27
(1,514 Views)
I have a hard time understanding. With a single index array, you can read all columns and write to separate graphs.
Message 18 of 27
(1,506 Views)
I think this will do what you want.
This assumes your text file is tab delimited. I tried it out by creating a text file from the image you originally posted.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 19 of 27
(1,493 Views)
cool .
and how to put it in three different waveform . each of them has his own waveform
Message 20 of 27
(1,476 Views)
