how to read a data selecting from sets of string.
hi
 how can i read a data from string.my output string looks like.:
for example
{<V01/DST62/SRC01/PT08/DT01><C04/R01/A00><P120.002​.001/R001/C001><2000>}:{<V01/DST62/SRC01/PT08/DT01​><C01/R01/A07><P120.003.001/R001/C001><6>}u and so on.But i need only the value  2000 and 6.i have to analyse more than 20 such output string.how can i read these value in my front panal?
Thank u.
Thakur
Message 1 of 10
(3,301 Views)
What data are you looking to extract? You need to help us here if you want help.
What do you need to do?
Will the string that you are getting always look like the one that you have provided?
How are you going to get the data?
What have you already tried?
Tim
GHSP
Message 2 of 10
(3,295 Views)
Match Pattern and Scan From String will be your friends here.
Message 3 of 10
(3,293 Views)
hi I am trying to get data which contains between <>.i have such more than 20 String that i received.each string  starts with { and ends with with }+Checksum.Then starts with{ next string for next data.but i fell difficulty getting so many string as output.I am not so gut in programing..
thanks
Message 4 of 10
(3,290 Views)
do i need  any loop or case too.Coz i have more than 20 string that i have to analyse.
Message 5 of 10
(3,289 Views)
Accepted by tadhika
Here is what I would do to start:
Example.png\
This will accommodate the multi string that you want to process. You just need to get them into an array to pass to the for loop.
Tim
GHSP
Message 6 of 10
(3,276 Views)
I think it really still depends on what the actual rules for the input string are.
I thought this:
Replacing the input string with an array and a for loop would work.  Or concatenating all strings together would work.
Message 7 of 10
(3,271 Views)
Or you can use a regular expression.
Ben64
Message 8 of 10
(3,263 Views)
wow..thanks it works .And can i use while loop in visa read for continuous reading a data?i used concanate string to send all the string.But Some string contains only the commands to be set and rest of them contains commands to get.e.g.in my above string C01 is for Get and C04 is for set.How can i read data continuously.i just use visa read and write with out any loop.(see attachment)
Message 9 of 10
(3,260 Views)
hi
Thanks a lot.Can i use while loop in visa read ?.Because i need to get data continuosly.
Tadhika
Message 10 of 10
(3,256 Views)
