how to record number of times for Case switching
Hi everyone,
i am using to case stuctur for switching between case 1 und case 2, want to record that how many times switchs it for case 1 →case 2 → case1,for example,1th case 1 →case 2 → case1,2th case 1 →case 2 → case1...
n-th case 1 →case 2 → case1,how to complete this function?if f anyone can give me some ideas that would be appreciated.
thanks in Advanced
Note:Labview 2009 sp1
(3,129 Views)
Hi jetfire,
maybe some pseudo-code will help:
IF case_now=case2 AND case_before=case1 THEN Increment Counter
As usual:
Show what you have programmed so far and we will help with adjustments/hints.
As long as you only describe your homework you will only get textual descriptions of the solution...
(3,125 Views)
thank your for your reply,here i posted my code,i want to using array controller for case switching with different period(period:case1→case2→case1,the index of  array controller indicates N th of Period,can your give me some advise?
thanks
@GerdW wrote:
Hi jetfire,
As usual:
(3,118 Views)
Accepted by jetfire
Hi jetfire,
as I wrote before:
(3,115 Views)
@GerdW wrote:
Hi jetfire,
as I wrote before:
thank you,i have a question about your code,why ist left shift register 3 ,right only 2 for case switching?
(3,110 Views)
Hi jetfire,
you should read the context heklp on shift registers. There are 3 shift registers used in the code...
You can drag down the left side of the shift register to access older values (not just of the iteration before, but also i-2...)! As given in the pseudo code you need to access the current vaule as well as the vlaue of the iteration before thus I oulled down the shift register terminal to show one more output...
(3,104 Views)
@GerdW wrote:
Hi jetfire,
ok,thank you! i will immediately read about  shift registers
(3,102 Views)
